why are you feeling the clutch needs adjusted?
yes she doesn't move forward until is almost all out.
Tha might be what I need cause I said before is not engaging unitl is almost all out.The clutch is not adjustable...that only changes the point at which 'you' feel the clutch engaging or disengaging.
could be that the clutch is worn.. as the plates go thinner and flatter, they tend to engage later and quicker in the release..
I have mine set on four!!! and it engages pretty quick!
the clutch is hydraulic and requires no adjustment.. (self adjusting)..Ok, but if I need to adjusted is to much work or anybody can do it.
the slave cylinder handles this nice little feature of a "juice" system
The only thing changing the lever does is "where" in the stroke of the lever in relation to the grip, the clutch engages/disengages.. personal pref's are the rule here. Some like it tight to the grip, some dont..
now that really would be a problem... I have only seen this on drag bikes however.. (aftermarket kits)What about clutch cable stretch?
