recall
This is the cam chain tensioner that affects 99-00 bikes. I got mine done in march of this year, if you have not done it or don't know if its been done, FIND OUT. It costs nothing, and not doing it could be expensive, ask K-S Waterbug........
DOES IT MATTER IF YOU ARE NOT THE ORIGINAL OWNER I GOT A 2000 BUSA AND I JUST READ THIS AND I DONT KNOW IF ITS BEEN DONE OR NOT. I HAVE NO WAY OF GETTING HOLD OF ORIGNAL OWNER THEY MOVED DOWN SOUTH THATS WHY THEY SOLD IT. CAN I JUST GET AHOLD OF THE DEALER IN MY AREA TO GET THIS DONE UNDER THE RECALL WITHOUT IT COSTING Me??? I ALSO READ ON ANOTHER SITE THAT THEY HAVE A PROBLEM WITH THE FUEL PUMP ALSO ANYONE KNOW IF THIS IS TRUE. WHEN I TAKE IT IN I WOULD LIKE TO GET ALL THE BUGGS FIXED AT ONCE I LIKE RIDDING TO MUCH TO LET THEM HAVE MORE TIMES THAN NEEDED.
THANKS???
                                                             THANKS???
call the dealer and have them run the vin.  If it has been done they will be able to tell you if not then Suzuki has to fix it.  I don't think there is a time frame that it had to be fixed by. The fuel pump recall was only on the 99s.
<!--EDIT|jwcfbd
Reason for Edit: None given...|1117213669 -->
