I have a 04 busa ive been dealin with that common prob of the bike not starting after its gets hot(normal temp long ride) had let the bike set and then it would start so i i cleaned off all the batt,starter,starter relay,and rr connections i attempted to test rr but couldnt get the right setting ong the multi meter so heres my finding testing off the batt
***note the rear led stop and turn sig where not connected all test where done at normal idle
batt bike turned off 12.4v
bike turned on hid lowbeam normal idle 15v
fan an hid running 13.3v
fan,hid lowbeam,regular bulb highbeam 12.2v
are these normal reading or should i do more test to try to correct this hot start prob after the test i let the bike warm up all the way up to normal temp turned the bike off n on about 10 times no slow cranks it cranked up very strong every time
any imput would be helpful my bike is my life thks guys
