Starter relay and fuel pump clicking sound
angel_t65
I recently swapped my 99 fuel pump and tank for a 06 tank and internal pump, I followed the post by ks-waterbug on this thread:
https://www.hayabusa.org/forum/general-bike-related-topics/80973-need-help-99-swapping-04le.html
for wiring the pump and fuel gauge.
When I open the ignition I get a clicking sound from the fuel pump and the starter relay the dash have the CHECK message and the needles on the dash flicker a little, I checked the service codes and the ECU have no codes (code C-00).
I have a 99 Busa with 40,000 k on it.
Can someone help with this, tanks in advance.
Re: Fuel pump and fuel pump clicking sound
Sorry it is not the starter relay it is the fuel pump relay that clicks. If I disconnect the fuel pump the clicking stops and check message is also gone.
When I turn on my ignition key, I can hear the fuel pump pumping, and the gauges do one movement to their extremes and back.
Is that the sound you hear?
