I wont even get into how long it took me to do the instal on the Micron Full exhaust, but have a few questions.
1) Between the Header and the Flange I was able to tighten them up enough so they touch...nice and tight (Dont believe over tight), but when I see the Akrapovic system pictured below I see the Akrapovic system has a gap. Should my Micron have a gap? Did I over tighten? Doesnt seem to have any leaks, and sounds solid, but could it be I messed up or does Micron just fir this way?
This is one of "Kriegs pics showing the Akrapovic system", I dont have this gap on the Micron, Im only using this pic as a refrence to show the gap I do not have.
Also, I reused the exhaust gaskets, is this ok. around 3000 miles on the gaskets, but they dont seem to leak, but than again maybe I over tightened the Micron.
<!--EDIT|valium
Reason for Edit: "Akrapovic system not Yosh system"|1122125477 -->
<!--EDIT|valium
