While reading the install guide for the Yousimura Alpha T system, I noticed this warning...
“NOTE: In order to maximize performance, the Yoshimura R&D header design restricts removal of the oil filter when performing maintenance services. To remove the oil filter, two options are available: 1) remove right side oil cooler hose and remove oil filter from right side of header, 2) remove lower radiator bracket and remove oil filter between #2 and #3 header tubes.”
Hopefully some patron here has the same exhaust and can offer insights.
Have I purchased frustration and trouble?
