snakeyezzz
I might have the opportunity to get an 08 motor, ECU, wiring harness, tac, switches, and everything to swap over to my 07. Will it fit? What are the pro and cons of doing this?
yes it'll fit. The frame is the same. If you've got all of the parts then go for it.
Externally everythings the same except the airbox/throttle body set-up. You might need the 08 tank to fit over the new style airbox......otherwise the 08 should bolt in just like the 1st gen motor did.I might have the opportunity to get an 08 motor, ECU, wiring harness, tac, switches, and everything to swap over to my 07. Will it fit? What are the pro and cons of doing this?
