re you usn#6 pin (Pitbull)!
Pitbul with a #6 pin works great on my Gen1 + Gen2
On your GenII does it go in all the way untill the bottom flare connects with the tripple tree?
I have the convertible front stand by Pitbull. It's a regular fork stand for everyday use (Which is far easier to use) and the pin on attachment for those rare occasions when I need to pull the forks off. Pit Bull makes great stuff but its not cheap.
I wish some one made a front lift stand , that clears the fender, doesn't hit under the nose, or remove or loosen the front fender!
Woodcraft, does not
Redline, does not
And from this post, PitPull has issues also?
Lockhart Phillips does.
My forklift stand fits right in the gen2.
No hassle, no issues.
No need to loosen or remove the fender, and it doesn't hit the nose either.
thanks for the tip..this will work to get the wheel up on the ABS model...... LP USA Sportbike Black Steel Fork Race Stand | www.Lockhartphillipsusa.com
made this few years back for fork work,since I have an overhead chain hoist
No, that's not it.
I have the forklift stand that lifts under the lower triple clamp.
The kind that allows you to remove the forks, not lift underneath them.
Woodcraft, does not
Redline, does not
