I jus got bike rebuilt when we tested the bike 2 see why it wasn't starting we pulled the plugs found that it was flooded..dried it out....checked plugs they where firing then moved on to fuel pump..we Un hooked my fuel pump ran another pump and some white smoke due too the rebuild i believe to be natrual.....but ran fine..... then I did further testing on my fuel pump took it apart cleaned it turned bike over like it's says in service manual...and the symptoms where too much fuel which led me to believe the regulator or the switch since flooding obviously is too much gas......but can't find a regulator nor does it come with the pump but only the whole assembly for $$$
