Dont think the 2.5 fits under the hump.
There was a US mounting kit I saw a while back to put a bottle under the busa hump.
I think it was a 2lb ? I should look it up. Cop's here dont like the gas on the street.
Bottle mounts depend on if it has an interal tube or not.
The pick up point, either the bottom of the tube or neck of the bottle should be at the
lowest point and at the BACK. many lean their bottle back to suit the lines of the bike
when the should be leaning forward. Try and picture the liquid in the bottom of the bottle,
you want it to fall towards the exit under accelleration, not climb the bottle away from it.
Im sure others will argue it makes little difference, but im a but fussy on these things.
I use the original NOS system for arming. A toggle switch that turns the horn button
into the "fire" button, and a microswitch on the carbs / throttle body's that only makes
it live at full throttle. You end up with a system that "hits" when you push the horn button
but ONLY at full throttle. You might find its a bit much in the lower gears.....
