gearhead77
I recently bought a stock 06 and really don't like the rear turn signal assy. What is the easist way to shave the turn signals/splash guard on a budget? Any and all help is welcome. thanks
i would like to see one done with a chainsaw... or a sledge hammer
busa186 & Strife would get a $1k ticket down here. "No solid back plate" said Miami-Dade Popo when I was parked with a couple other GSXRs that had altered their tag mounts.
So to be the law abiding citizen I am, I cut (dremel) my fender even with the bottom of the tag and followed the contour up to the underside eliminating the factory turn signals and got a Clear Alternatives tail light with integrated turn signals (Popo said OK).
You may want to check your local laws before cutting.
That little mod makes what they call 'improper display of tag' in so many words. No one was cited in our case, but we got educated!
Remove plate bracket turn it up side down slide it as far up as it will go and drill new holes.
Draw a line around the bottom of the upside down plate bracket and the signals creating a pleasing to the eye radius and trim off excess with a dremal.
cheers
ken
