xpigrider Registered Feb 14, 2005 #1 What rpm is good for shifting when racing, 8000, 9000, 10000, or 10600. When does the HP or torque start to fall off? Thank you
S shenoyp Hayabusa Master Jedi Donating Member Registered Feb 14, 2005 #2 Check the dyno results dude... and decide for yourself I'll try to get you the dyno chart for the busa... is it stock
S shenoyp Hayabusa Master Jedi Donating Member Registered Feb 14, 2005 #3 Well here is the dyno chart (Stock)... Picked it of some website. I hope its right....
xpigrider Registered Feb 14, 2005 #4 Thank you Shenoyp!! I will set my shift point at about 9900rpms.
Black&Bluebusa Registered Feb 14, 2005 #5 My 02 drops off @ approx 10.5 and stops pulling even though red line is higher than that. I guess it's all in the curve. I'm sure every Busa is going to be slightly + or - what mine is. Pat
