If you go that route make sure you look at the front and rear wheel chocks out there.
Do like i did. 7X14 vnose wich makes it really 7x16.5 and plenty of room for 3 busas and lots of gear...
If you run strapless stands it makes much more room inside. You wont have a bunch of straps/trip wires running allover the place.
I have a 6' x 12' v nose (6' x 14' with the vee). I can haul 3 Busas and gear... I'm using Baxley Sport Chocks....
Are the Baxley's strapless? Or...in general, are wheel chocks by nature considered to be strapless? From what I've gathered in previous post navigation, are straps still preferred for added security even with "strapless" chocks?
If you get the front and rear wheel chocks you shouldn't need to strap it, but added security never hurt anyone. By the way; I bought the canyon dancer for the bars and then bumped into a few friends that told me it was better to just go between the front fender and nose cowl and strap to the lower fork clamp. So you have many choices.
If you go with the front and rear chocks, I would just do a check and make a determination then.
They can be strapless, however, two straps from the passenger pegs pulling forward will make the bike very stable.
Sweet! Thanks a ton guys...and I appreciate the pic. That does look like a pretty stable mount.
I have the 1" spacers under the tripletree top plate so I have been a little apprehensive about strapping to the bars. The rear pegs and lower fork clamp would be perfect alternatives.
Again...many thanks for your suggestions
That's the Baxley Sport Chock...
Man...that does look good too. Definitely looking into those once I get set in on a trailer...
I'm gonna go broke before winter! Just bought a set of gold factory wheels off Takeuon's K8 blue and a Yoshi R-77 full from Greg/Terra at HPC...knew that Fall Busa Bash was gonna be trouble!
omslaw.. i want your trailer... !! very nice!
