sounds like a good starting point. your engine/head/cam/etc all influence what cam timming may be best. You'll have to experiment a bit. Since it's a dual cam setup there are additional variables. In general to bump the hp peak further up the rev range you would retard the cams a certain amount of degrees. Again, Since it's a dual cam setup there's more room to play but you still have to watch valve to piston clearance.
