infidel
I really needed to clean up the rear of my bike, and these things are just the ticket!!! The rear blinkers were mounted on a SW Motech rack mount to make them more visible with the Givi hard cases. It is effective, but not too nice to look at, especially with the racks off.
These blinkers are made in Canada, and seem to be VERY high quality! They are cast aluminum (I think) and everything from the paint to the wire connectors are well done.
The wiring includes a resistor loop to keep the blinker working at the correct rate. It works as promised.
As the wiring does not run through the stud, you'll have to drill two holes. One was 5/32 for the stud, and the other was 1/4 for the wires. I believe they are 7/16 on center.
They are very small! They are also considerably brighter than stock. I also like how the LED goes from ON to OFF without the "fade" of an incandescent bulb. I highly recommend these!!!
PS- They did cost $127 eoples:
