@Skywalker , I do not think you are supposed to be able to turn the bolts once they are tightened bro , I got 2 sets of BST and both don't turn once tightened .
When I first fit those M10 ti bolts to the carrier , they were a tight snug fit , I had to use CRC to work them in place , and for each carrier . Then torqued up with allen key holding the carrier bolt from turning while I torqued the nut .
I remember the grade 8.8 steel bolts that BST supply with the wheel being real easy to slide into place in carrier in comparison . But once torqued , regardless of bolt type , to spin / turn like that would be scarring the aluminum carrier wouldn't it ?
I was thinking , you racing this bike with BST 's , your track bike is it ? I am wondering if you have somehow hammered the already loose BST supplied bolt tolerance , so it now allows movement sideways , like an elongated locating hole , but sprocket not actually able to move along the bolt length because of nut holding in place , so probably fine still for chain alignment .
You can buy replacement sprocket carriers from Brocks , anyway good luck bro , it has been puzzling me since you first posted this !!
Ok, I'm up and had my coffee and going to check all the torque specs on each this morning. I do not race my bike and only have 1200 mile on her. I have had the front end up just once but it has always seemed solid and never felt anything wrong. I appreciate all the inputs and its just one of those things that my memory is bad and when I seen that my first instinct was... they are all backed off. I'll check it all today.
