Valve springs removal question
Aly Kabil
can anyone tell me if there is any way or tool to change the valve springs while the engine is still in or i have to pull out the engine or at least the head... if there is some way does it need some special tools?
just want only to change the springs without make too much headache and time in the garage
Mr Brown
I'd say you'll at least have to rotate the motor forward to get to them. Not sure though.
My question is why you're swapping for gen 1 springs?
rubbersidedown
BUSA-RIDIN'-BASTID
Missed the part about gen I spring swap,but its late for me[4:47 AM]
Some Gen I parts are better.Richard at RCC Turbo's put Gen I shift forks in my build. There have been a few swaps out there worth doing.I helped a drag racing member out once on a swap for my aluminum sub frame for his steel to save him weight. I think there was a recall on the alum. one's,they had a tendency to break if you carried a pillion. [fat chic]
Back in the day...some would fill the combustion chamber on V-8's with thin rope to hold the valves up for valve seal replacement. This dude I knew custom made a spark plug with a hole down the center and filled the chamber with a constant flow of compressed air.I'm sure there is a better way.
1616562
Not sure if this is what yer asking. I believe Mr.Brown ^ is correct on a motor tilt to clear the frame with head removal. Rubb.
Mr Brown
Back in the day...some would fill the combustion chamber on V-8's with thin rope to hold the valves up for valve seal replacement. This dude I knew custom made a spark plug with a hole down the center and filled the chamber with a constant flow of compressed air.I'm sure there is a better way.View attachment 1616562
Yeah, some gen 1 parts are better, and the valve springs are one of those parts I believe. Just didn't know if doing this was necessary for his power goals.
GIXERHP
This will work, but iyou need to have good compression!
Aly Kabil
to spray nos in gen2, and i have gen1 springs so i decided to use them so i can be able to spray 80 shots
Aly Kabil
its much more easy in cars than bikes cos you have huge room to work not like bikes it so small room
202mphbusa
Haven't done it on a busa but many times on cars and lawn mowers ive used a leak down tester to fill the cylinder with pressure to hold the valves while pulling the springs
Problem is.......on a busa even if you use air or rope to hold the valves up the springs are in a bore. that makes it hard to push down on the top and still get at the keepers ESPECIALLY when putting them back in. don't get me wrong I have done it. but find it is so much easier and safer with pulling the head
Aly Kabil
you did it while the engine still in the bike or you removed the engine out of the frame???
Thread starter Similar threads Forum Replies Date
Johnnie Phatt Gen 2 boost vs valve springs. General Bike Related Topics 5
bigbusabigbusa valve springs General Bike Related Topics 12
P Valve springs in turbo engine All Motor 4
RedFalco Heavier Valve Springs and Retainers (any advntges?) Nitrous 10
hayabusa99b/w heavy duty valve springs do u need aftermarket retainers? Turbo 7
M Gen II Valve Springs/Retainers/Cam Chain Experiences? All Motor 13
X Head have to come off to do valve springs? Gen II Busa Information 4
G Gen II Valve Springs Gen II Busa Information 19
turbobusa2000 Valve springs and Ti retainers Turbo 10
grasmick6250 Valve springs General Bike Related Topics 10
G Valve Springs Turbo 10
O valve springs and seat pressure Modifications & Aftermarket Equipment 10
harrisonj89 Valve cover gasket. Failure Stage 1 Turbo 8
F 2005 Hayabusa issues, bent valve? General Bike Related Topics 6
B valve clearance - my excel calculation-sheet Maintenance and Do-It-Yourself 0
C Checked valve clearances today - need advice. Gen II Busa Information 31
c10 Video of valve clearance inspection. Gen II Busa Information 24
T Variable Valve Timing Random Thoughts 7
WuzzaCBXRider New tire on the Z and an angled valve stem General Bike Related Topics 7
B Broken valve spring retainer Busa problems 5
K Pair valve wiring General Bike Related Topics 1
Sandow Ear Porn 2 or What is a exhaust control valve?! Off Topic 1
O Valve clearance check New Owners Forum 17
c10 1st valve check @ 24,000 miles Gen II Busa Information 5
B Pair valve block off General Bike Related Topics 21
Kiwi Rider Valve Operation at High RPM's All Motor 9
WuzzaCBXRider What’s Suzuki call a cam/valve cover gasket these days? General Bike Related Topics 3
gack pair valve marble mod General Bike Related Topics 3
Barrocker Valve seals General Bike Related Topics 4
greg3852 Pair valve gasket? General Bike Related Topics 5
Jose J Ortega Smart TRE and Pair Valve benefits Engine and Performance mods 22
Jose J Ortega Random Question... (Compression test/valve clereance) Maintenance and Do-It-Yourself 2
ky busa 1st Valve Adjustment At 67000miles Here Is What I Found (pics) General Bike Related Topics 28
T Idle Speed Control Valve Question Turbo 31
PADEROLIS Valve Adjustment Service; Should I? General Bike Related Topics 18
ky busa Gen2 Valve Adjustment General Bike Related Topics 7
Rivercop UK Pair Valve / Ecu Editor Question Gen II Busa Information 14
Ham Valve Stem General Bike Related Topics 5
Davidvon Checking Valve Clearances On 2006 Gen. 1 'busa Maintenance and Do-It-Yourself 2
Taribare Fuel Valve Problems *was Posted In Mods Should Be Here* Busa problems 4
Taribare Fuel Valve Problem Busa Mods 2
Blue Bayou Valve Stem Failure..... General Bike Related Topics 9
SSGT_B Help Please. Valve Train Noise :video Busa problems 6
jgixxerjoe@att.net 2007 Busa Pair Valve Removal. Engine and Performance mods 2
sjg34 Air Shifter Air Valve 1/4 Mile 3
Monedogg Need Valve Stem Replaced 911!!!! General Bike Related Topics 0
smac Pair Valve Question Gen II Busa Information 5
F When is a blow off valve needed? Over 10 psi? 15? 20?... Turbo 12
c10 Truth about the Pair valve system ! Gen II Busa Information 21
Kevin Jones broken check valve from throttle bodies to map sensor Turbo 3
Similar threads
Latest Bikes
  • A blue bike
    2017 blue & black
    • Hayabusa Wannabe
    • Updated:
  • 2011 busa
    • Hetheus
    • Updated:
  • New guy here
    • Los.great.beard
    • Updated:
  • My 2014 Hayabusa
    • Dljat2
    • Updated:
  • Hi Everyone
    Loved
    • BirolBora
    • Updated:
Forum statistics
Threads
174,198
Members
48,297
Latest member
Richbusa
