Barrocker Registered Mar 30, 2018 #1 Can you change valve seals while the engine is in the bike? 03 Busa
POWERHOUSE Frank Donating Member Registered Mar 30, 2018 #2 Yes you can it’s a mistake but you can and I would not advise it !
GIXERHP ok, ok...just a wee bit Irish... Donating Member Registered Mar 31, 2018 #3 Barrocker said: Can you change valve seals while the engine is in the bike? 03 Busa Click to expand... Same my reply to your PM, Also as Frank said, not advisable On a 2 valve head/ car, yes, but there is way to much that can go wrong
bigoltool Registered Mar 31, 2018 #4 Used an air compressor to do this before on my truck, not optimal but it does work.
greg3852 Registered Mar 31, 2018 #5 2 hours taking your time and the engine can be on the floor. Easy to do.
