The Magic School Bus
Ok just throwing it out there, I see a ton of valve clearance threads, tried to sift through most of them for wisdoms. I have been preparing for days and today I am opening the cylinder head cover (my first time doing this).
Patient- 2005 GSX1300R 36,000 miles
First thing I am doing is installing the manual cam chain tension adjuster by APE. Then, I am to inspect the chain and guides to see what parts to order ( I've shopped for worst case scenario- meaning replacing everything without removing cyl head- hoping I've found decent prices and quick shipping). Once I've done that and have my parts on the way I'm going to check valve clearances. Wish me luck! If you have tips and links to helpful threads, videos, or stores selling the necessary gaskets, guides, chain, shims, etc. feels free to share. Right now I'm looking at OEM or lightly used guides on ebay. Also, found a new OEM cam chain for $99, a D.I.D. cam chain for $90, cylinder head cover gasket & (4) spark plug tube gaskets for $50, set of (6) valve cover bolt seal washers for $30. I'm reusing the gasket for my tensioner adjuster + red RTV and I'm using a shorter bolt + reuse (steel?) banjo washer + red RTV to plug the crankcase oil outlet that fed the tube to the stock adjuster. I am using these threads and videos to help: JINKSTER's "INSPECT" and "ADJUST" threads and David von Wolffersdorff's '06 valve clearance YouTube video, and of course my cyber pirated suzuki 99-00 service manual (wish I had 2005 supplement). How's all this sound? Am I on track so far? Thank you for your attention!
