turn signals not working
BUSA SS
Got the clear alternatives tail light set up with the flasher unit.Installed it thursday and it worked fine.Went riding with a friend friday and when I would signal it would stay lit.Then they stoped working all together(front and rear).Everything is still hooked up like it was to begin with.Tail and brake light work fine.Any help would be greatly appreciated
MC MUSTANG
Can you take pics of your set up? Also, check and make sure that there are no breaks in your wiring and that the fuse is good under the left side inner fairing.
BUSA SS
Forgot to add that we that we stoped and checked the fuse and it was good.I'll swap another one in right now just to make sure
heavybusa
Just another guy
+1, you have to rule out a loose bulb or wire and/or fuse before you start taking stuff apart.
Do you have a test light?
BUSA SS
No blown fuses.Can't get any pics(cams broke).I got a test light just have to track it down.Thanks for the fast response guys.
MC MUSTANG
When you say flasher unit, do you mean an integrator or do you mean a flasher relay? Also, did you use inline resistors? If so, check those and make sure they are still wired tight.
BUSA SS
I'm assuming it is a relay.I had to pull two wires out of the the stock flasher and plug them into the new one that they sent me.It says that I will now have two flasher units.Did not use the relays.
BUSA SS
Found the problem!The flasher that I got from them is junk.Put the wires back into the stock flasher and turn signals work now.Thanks again guys
MC MUSTANG
Got your message, that was why I gave you my number... I was gonna have you do that and see it if fixed the problem...
Oh, and Welcome!
BUSA SS
I have to say,I belong to two other fourms(4wd.com and ImpalaSSfourm.com)and never have I got such a fast response from them as I did here.Usually it would take two days if at all.I'm glad I found this fourm.You guys are awsome.Thanks again
Sam
MC MUSTANG
(BUSA SS @ Sep. 09 2006,15:31) I have to say,I belong to two other fourms(4wd.com and ImpalaSSfourm.com)and never have I got such a fast response from them as I did here.Usually it would take two days if at all.I'm glad I found this fourm.You guys are awsome.Thanks again
Sam
That is because you had a relatively easy problem. Now if you needed to know what a TRE is, or which side of the bike was which, you'd be waiting for awhile, cause none of us know!
