was working fine up until last week, saw I must have a fuel line kink as the filter was sucked in (like it was soft and the sides melted in slight) on a hotter day (85 or 90 degrees) ... so over the weekend I installed fuel line springs on both the fuel line going to the pump and the return fuel line and a race fuel filter inline on the low pressure end side of the pump. replacing the Velocity Filter. the filter will flow more then the Velocity and filter to 50 microns.
its mapped for pump gas 94...
heres what happens:
1. it will build boost up and if I shift the BOV will let out the boost.
2. my spring is a 4# spring for low boost and it will build up to 4 lbs on the guage and kick in for a short time (say 3 seconds) if thats all I need
3. if I keep rolling on the throttle when it hits boost after the initial pull, it just drops RPMs quickly. So I let off the throttle instantly *(dont want to burn anything up).
4..doesnt matter what speed just under heavy boost the engine just feels like you let off the throttle but when you accelerate again its fine.
5. can run the bike perfect as long as I am not under boost. runs fine at 100 mphs
6. when shifting and riding it is pulling vacuum on the boost guage.
any thoughts? I checked the fuel lines and nothing looks kinked and I installed fuel line springs to make sure...
could it be the fuel pump?
<!--EDIT|Clueless
Reason for Edit: "tracking post"|1122177461 -->
heres what happens:
<!--EDIT|Clueless
