Hey guys I will give as much info as possible so hopefully you guys can help me I have a 2000 with a lees performance 1397/full brocks alienhead/complete aftermarket fuel system (pump/reg/injectors). I recently installed a power commander 5 as I had an ancient 2 and my tuner could not tune the bike with the old one. I am having issues with the bike surging/bucking and not very good throttle response. After he tuned it with the power commander 5 the bike ran great for about a month then it all started again and has progressively gotten worse.I called him and asked why the bike would start running like this again? I explained that the bike had the pair valve converted to a pump through the crankcase and that I have read that the bike had to be tuned differently because of that. He said that would make no difference on tuning the bike. Something is definitely going on to not be able to hold a tune for more than a month. Should I do the pair block off and have it tuned again or leave it as is or??? Or does the pair "pump" have anything to do with my problems? Thanks. EDIT I also want to add that the throttle bodies were synced and the tps set when he dyno tuned it. I rechecked the tps after it started running bad again and its still right in the middle.
