With the intercooler and some mapping you would be right at 300 HP, with a stage 2. But with a turbo you are gonna be rebuilding the engine every year or so from the added wear a turbo puts on your engine. Not to mention additional parts you need to run a turbo properly. So in the long run HOW MUCH do you spend on a turbo? A lot more! A Supercharger will run for five years without going into the engine once! The powerband on the supercharger is smooth and consistant thruout the throttle.
So you can really enjoy mid range twisties and high speed passing on corners at the track. Try doing that with a turbo!
Turbos kick in and launch your front tire everytime, try doing that on a corner passing! Superchargers have alot more to offer thru a much wider powerband. Turbos are good when you want one thing=Straight line power, and plenty of it.
<!--EDIT|Xcellerate
Reason for Edit: None given...|1118651772 -->
