Top Speed with My Mods?
snbusa
2011 with full Arapakovics, P Commander V, and K&N Filter should give me about what top end since I don't yet have the horns to find out. Also HP? Thanks.
And believe you me you want to remove all those restrictions. Its a totally different experience after that. Thanks to Kromdom :)
186
But if you remove the top speed limiter, you will have more.
Is your bike tuned, or are you using a generic map?
As for the K&N most tuners will tell you you that the filter is a restriction.
This is, lol:whistle:
WHATS A TRE?:rofl::rofl::rofl:
186
Sorry, only know that the guy who traded it in was meticulous about everything so infer what you can with that.
Looks into my magical crystal ball............ I see hmmmmmmm 186 MPH and the magical HP number if 186RWHP hope that helps you sleep tonight
Well a good thing to put on your list of things to do, is have it tuned at some point!
Stock gearing on any year gen1(17/40 gearing) that is or has been desrestricted has a potential top speed of 194mph.
Stock gearing on a derestricted gen2(18/43 gearing) has a potential top speed of 197mph.
This is what the bike is capable of, rider weight, temperature, humidity, wind, elavation, ect., all play a big part in whether or not you can actually go that fast.
A gen2 needs a 41t rear sprocket, or a 55 series rear tire with the stock 43t sprocket to be able to break 200mph.
Ballpark gains from full exhaust and filter are 10hp/5 ft lbs trq...give or take a few. Every bike and dyno are a little different.
So what is a good gearing setup that you would recommend for a gen1 to hit the big two-double-O?
17/38, 18/40, or maybe stock 17/40 with a 55 series tire should give you the gearing to get there.
I doubt that you'll have enough motor to get their though(maybe with perfect conditions and a flyweight rider).
Pm Gotbusa? he can answer your top speed questions.:beerchug:
