I'm getting ready to do my Muzzy ti exhaust, and while the oil pan is "un-trapped" I'd like to remove my counterbalancer. I understand that the aftermarket crank guys remove the drive gear from the crank. My crank is not coming out. Can I remove the driven gear from the counterbalancer or at least grind the teeth off so that it doesn't spin? Is it ahead of, below, or behind the crank? Which side is access gained from? Where is the oil hole(s) that I need to plug? I am visualizing tapping and plugging a small hole. I am ASE certified and have built engines and raced cars for years. I got the black UNI filter foam #BF-2. Is that the right stuff? What do you oil it with? Do you attach it with RTV? I have some black GMS type RTV. Do you support the foam at all? Thank you very much. I appreciate your help.
