Testing for parasitic draw
newtonx
I suspect either my new battery is not good or my bike has a parasitic draw, draining amps continuously. So, I did a test with a multimeter and got 0.55 mA. Is this value normal?
(Dang, correcting this post. It is too early in the day!) I think the manual specifies 3 mA or .003 A maximum draw. Is the decimal correct? If yes that is in spec.
  • Like
Reactions: c10
@c10 0.55mA is less than a fifth of the maximum leakage allowed thus why would it be a drain? Unless the decimal in the reported number is off.
That's enough power to run my relays or strobes in fire alarm . While .55 ma is very low it is enough over time to bring voltage from 13.2 to sub 12 vdc ,and at this point not enough voltage/ amps to crank the starter motor under load
I googled fire strobe specs. I suspect your strobe is operating in the range of 50 mA, or one hundred times his posted measurement.
That is okay, the OP has a problem but his specs is beautiful so in that same vein @newtonx make sure and confirm that you have the correct scale for your measurement!. That could be a great result at 0.55 mA or the big leak you suspect if it were otherwise 550 mA!
From the picture, I guess... it is 0.55mA right?
My electronic knowledge is next to zero, is my interpretation correct?
If that is an "m" next to the "A" then yes your reading is right, 0.55 mA, and the manual allows for up to 3 mA, so that would be good. A second verification test would be to measure the battery voltage disconnected then remeasure the battery connected to the bike. The voltage should only have a "small" drop, ex. 12.85 to 12.75 V.
It sounds like there is no draw thus can you get to an auto parts store for a free load test of the battery? (It should be fully charged first with a smart charger.)
