This is my first post on here. I have a 2004 Hayabusa Limited Edition that is in MINT condition (10k miles) with the exception that my temp or heat gauge is stuck on HOT or MAX at all times. Even with the key out the gauge is still all the way up on HOT. When I put the key in and turn it on, the rest of the gauges ALL sweep to max and back down EXCEPT the heat gauge. The little red light DOES come on in the temp gauge but the needle will not move at all, EVER. LOL. About the only thing I havent tried is unplugging the gauge cluster wire harness plug to see if the needle stays at HOT/max...
I have heard that an air bubble in the coolant system may cause the fan not to come on and other problems, but my fan works (comes on when it gets hot, turns off after a few mins as it cools) and it doesn't seem to run hot or anything. I have also unplugged what I thought was the sensor (at top left of radiator) for the gauge and the needle wont move at all (stays on HOT/max). I am wondering if it is a prob with the mechanical part in the gauge cluster. If it is a prob with the gauge itself, is it possibe to replace only the temp gauge in the cluster? Just wanted a little more info before I remove the nose... AGAIN! LOL.
ANY HELP IS VERY MUCH APPRECIATED! THANKS.
here is a vid of what it's doing...
