Tank mount weight savings .
You are certainly dedicated to losing every ounce of weight off that bike Bryan. I wish I had even a drop of your perseverance to this cause.
Maybe, just maybe, I'll get motivated to shed a little weight off my bike also some day....
Mine is still on the heavy side , I cut the bottom plate , used the pivot plate as bridge , then scored aluminum countersunk washers , and fitted M6 titanium bolts to fix tank and bracket to frame . I run a M6 bolt through the heavy pivot , and a lightweight M6 aluminum nyloc nut as the thread in my steel bracket is re tapped and weak .
