Billy Busa
Banned
On a new 2008 Hayabusa, at what milage should you put Synthetic oil in?
THE DEALERSHIP PUTS IN WHATS "CHEAP". I would go with a specific motorcycle systhetic oil.{it runs smoother, cooler, less wear, will not break down nearly as fast, etc, etc.} With the new materials being used in modern day rings and sleevs things "seat" quickly". 500 miles then dump in the good stuff.Ahhhh, I see...Well, thanks Cookie for going into detail with that, I am pretty confident that the Suzuki Dealership will be using what they think is best for my Busa, I'll have to find out if they will be using Synthetic or not. Apparently you think they won't be. I have to run, I need to get ready for this car sho this morning! Have a nice day!
For a second there I thought I might have been in the old school forum. I had to make sure I was still in the new age stuff. They never made a roller bearing crank for the Hayabusa.The mechanic I use is big time negative on pure synthetic when engines have roller bearings. He's a total gear head, and he's really into racing.
He recommends a synthetic blend due to pure synthetic being too slippery. Roller bearings tend to "slide" vs roll which can cause "flat spots" on the bearings.
SLA1500.......Your friend may be a total gear head, but not a well informed one. "roller bearings sliding" GEEEEZ, what nonsense. He needs to get out of his garage and do some learnin'. That is some pin-headed Harley folklore, besides you aren't riding a two wheeled tractor...............
Ron
87 octane? I will never put 87 octane in my busa or I might damage the engine, I hope you dident.Heres some info I found:
600 miles 5000 rpms - change oil at 600. use regular oil (not synthetic). Get a couple of good throtle twists in 1st gear up tp 5000 to seat everything.
601 - 1000 8500 RPMs After 1000, redline.
Change oil at about 1600. Use Regular oil (not Synthetic)
Change Oil at about 3000 - Use synthetic blend (Motul 10 - 40 or Castrol ACTEVO 10 - 40)
Stay with 10 - 40.
Also use 87 octane. 93 will cause you to pick up a lag.
+187 octane? I will never put 87 octane in my busa or I might damage the engine, I hope you dident.Heres some info I found:
Stay with 10 - 40.
At anytime you want and you can carve it in stone .On a new 2008 Hayabusa, at what milage should you put Synthetic oil in?
What!Well,, you have a totally different thing going with what you bought into. They will run a non-synthe every time,, unless you take them in four quarts of whatever favourite you choose. If you take in your own oil,, you are kind of defeating the purpose of that 1500 buy in.
Recommended? No, but it does run a lot smoother with the synthetic juice over normal dino oil.
I have run Mobil 1 car oil in my Busa since new,, and always will. Gold cap for me. But whichever,, is a personal preferrance.
There will be pros and cons on car oil as opposed to specified motorcycle oil,, but the argument will always carry on, regardless. It really comes down to the different ingredients in either one (car or m/c) as to whether one of the other needs a certain additive to take car of a catalytic converter or not.
