It's definitely oblonged, but you still should be able to press a bearing in. I still don't see why it shouldnt run true after a bearing was pressed it. If you look at the picture it does look like the entire thing is a different diameter. It kind've does look like it was dropped, but material was definitely removed from it. Did a reputable power coating business do it?
