sugarminnot
Are the SUZUKI PAIR VALVE BLOCK OFF PLATES needed for the 08? I'll be running aftermarket full system, and air filter. Later I'll be getting the Weber BILLET CAMS, BOLT-IN.
No, not in my experience, they aren't.Are the SUZUKI PAIR VALVE BLOCK OFF PLATES needed for the 08? I'll be running aftermarket full system, and air filter. Later I'll be getting the Weber BILLET CAMS, BOLT-IN.
Not if you put a resistor in the circuit.Whatever you do, don't remove the PAIR solenoid. It can / should be blocked off with a simple plug on the right hand side of the air box if you are running a PCIII with pipe, but if you remove the solenoid (located on top of the valve cover in front of the coils) the ECU will throw a code.
Your correct. Have you done it. Can you share details?AM -->Not if you put a resistor in the circuit.Draco1340 @ Feb. 13 2008 said:1295301[/ATTACH] AM]
You need to find a real tuner thenNo, not in my experience, they aren't.Are the SUZUKI PAIR VALVE BLOCK OFF PLATES needed for the 08? I'll be running aftermarket full system, and air filter. Later I'll be getting the Weber BILLET CAMS, BOLT-IN.
I installed the Yosh 4-2-1 R-77 full system, and I am experiencing no popping on decel, or any other issue/problem with the fueling.
On the recommendation from HPC, I am not running a PC-III nor do I intend to. Neither have I done anything to the PAIR system. It is unobtrusive with regard to my bike usage, so there is no compelling reason for me to alter it.
Um.... nope. Pretty sure I don't have to do that.You need to find a real tuner then
Interesting.I installed the R-77 full system on my otherwise stock 08 and did have popping when i removed the baffle.
