Suspension problems
Kiwi Rider
How do I tighten my suspension up so my undertail stops hitting my back tire
Welcome along to the Busa forum!
Take a moment to introduce yourself in the new members section and all your questions will be answered.
We need info about your bike's set up.
Is it stretched?
Is it lowered?
Is it a street bike or drag bike?
Stuff like that is helpful to say the least.
Johnnie Phatt
assumoing it is stretched
and
assuming a stock shock on the back you will need a stiffer spring in all likely hood preferably with a better valve shock
However if you follow the advice above from Kiwi river and and ottafish the advice they can give you will be. far more accurate to your needs
Kiwi Rider
and
Hahahahaha! Thanks Johnnie . . . made my day lmao!
fallenarch
THE SLOW RIDER
Is it stretched?
Is it lowered?
You forgot the most important question:
When you lane split are your hips the first thing to hit other cars?
Nastee
Welcome to the Org. If posting a question you need to check back in order for others to help with your exact setup & needs (how you are going to use the bike and what you have; Gen 1 or Gen2, stock, show, drag, track, street or a combination of uses, stretched, wide tire & Your weight). Price range for new parts or if just trying to make what you have better.
ScottyT
I have a stock 2006 hayabusa that's stretched 12 inches had it lowered to the last hole but had to raise it to the middle hole the under tail was hitting my tire I weigh bout 210 and want it lowered back all the way again so I can ride it on the street and drag race
Mr Brown
Pull it back in or buy an extended tail are your only two options if you want to retain suspension. 12 inches over is slowing you down on a stock motor, so I'd go that riute. Also at that length your stock shock is past the mechanical limits of its usefulness. Look into an aftermarket alternative.
ScottyT
Thanks
Latest Bikes
  • 2011 busa
    • Hetheus
    • Updated:
  • New guy here
    • Los.great.beard
    • Updated:
  • My 2014 Hayabusa
    • Dljat2
    • Updated:
  • Hi Everyone
    Loved
    • BirolBora
    • Updated:
  • 3-wheeler Touring Car
    2002 BMW K1200RS built into a Grinnall Scorpion 3 800lbs 130hp
    • K-Clive
    • Updated:
Forum statistics
Threads
174,151
Members
48,272
Latest member
Vleis
