Stock suspension settings for GenII
fadiizzaldin
Dears,
anyone knows what's the stock suspension setting (for both front an rear) and whats the fork oil weight on Gen II Busa?
Thanks,
Telboy2000
Stock fork oil is a Suzuki spec that is a weird weight...something around 5w.
Settings are
Front
comp............8 clicks out from fully clockwise
rebound........8 clicks out """
preload.... 6 turns out """
rear
comp........8 clicks out
rebound ......12 clicks out
preload.......manual says get the dealer to do it....but 10mm of thread above the locking rings suits most
however....these are so-so settings and don't really work on some roads
SimiPair
SportRider Magazine recommends:
Front spring 6 out, compression 7 out, rebound 6 out.
Rear spring 10mm, compression 7 out, rebound 7 out.
sixpack577
Top Gun
That's a shame...you might learn something
if you read your owner's manual...some good
info in there.
Some BS in there too, like the rear tire being set to 42 psi.
FallenArch is right, there is no correct or specific setting for everyone.
It's called suspension sag, and needs to be set for the specific rider's body weight(with gear).
BA BUSA
MotoGP Wannabe
There is a correct answer for the OP's question. It's
in the owner's manual...those numbers are a base line.
sixpack577
Top Gun
Still, like I said, it's BS.
If one rider weighs 150lbs and the next weighs 250lbs; how is there a "baseline" setting?
There cannot be. Sure, Suzuki gives you a random set-up recommendation, but that's all it is, random.
A free suspension sag set-up should come with the sale of every new sportbike.:beerchug:
BA BUSA
MotoGP Wannabe
What was the question?
dadofthree
Seasoned Beef
Ba and Telboy2000 answered the question asked. Telboy2000 was specific. Everyone should know that these settings are baseline and typically for a 165 pound pilot from everything I've read. I also read that If you weighed north of 200 the Gen I couldn't be set perfectly because the suspension just wasn't designed for us big guys. I read that the Gen II had suspension upgrades ( heavier front fork springs ). Fallenarch and sixpack make good points. Setting the suspension right on these bikes is best left to experts and if you're a big boy and you want to set the bike perfect you better get on the phone with an expert an order fork internals and a new rear spring minimum.
I wonder how much delta there is if you set the bike in the summer and go riding during the winter.
This knucklehead has never touched the suspension on either Busa. Not an expert just opinionated :laugh:
E Zurcher
These are very close to the settings I use on my 09 and I weigh 250. Only diff is my spring preload (5 out) and rebound (5 out) on the front end. This makes the bike respond evenly front and rear on dips and concrete slabs. I found any increase in spring/compression/rebound damping from these settings made the bike too harsh. These settings were obtained through much trial and error and are optimised for comfort and slightly spirited riding in the twisties.
I have never bottomed my bike and it handles well for my style of riding and my abilities.
When I decide to refresh my front and back ends, I will have the suspension work done but I don't see doing it until it is needed. I am not a track guy and not overly agressive rider.
For someone over 250 lbs, setting sag is useless because the stock springs will not let you get there. My guess is you won't get there if you are over 225 or so bu I'm sure someone will chime in.
jellyrug
I have never bothered with that.
If I weigh myself and go to possibly better settings how is my ride going to improve?
BA BUSA
MotoGP Wannabe
With your suspension adjusted properly, your braking
and handling will improve, tire wear will improve, ride
quality may diminish (suspension will be stiffer) with
practice you can increase you corner speed quit
a bit.
sixpack577
Top Gun
BA Busa is spot on in his response.
Also consider that the stock suspension factory "settings" are really specific to no one in particular.
More so, I have bought a few new bikes over the years, and my friends combined have bought many.
I've set the sag on a lot of them.
Of all these bikes, you be surprised to know that most forks aren't even set the same left to right.
You never know where the suspension is set until you check it.
Garbage settings vs. proper sag is night and day.
Yes, it can result in a stiffer ride for the street, but then again it all depends how much sag you want/need.
My understanding has been 35 to 40mm for street, and 30 to 35mm for track(as tracks are much smoother).
If it's too harsh, then you can always increase sag some, as your riding is not at the level to need such handling; as in you want smooth and comfortable as opposed to railing corners.
Regardless, set the sag and be amazed. The suspension will work under the bike as it should. As opposed to being a pogo stick bouncing you over every bump, as well as sloppy handling and hard diving under heavy braking.
You'de be surprised the looks on people's faces once their sag is set. Even, bouncing the bike parked and turning a few clicks to make the suspension compress and rebound quickly(and without a double bounce at the return)can make a Big difference...then fine tune it by properly setting the sag.
Try it, you'll be amazed at what you've been missing.
I've been setting sag for a long time now. But it wasn't til a couple years back that TufBusa(old bastid), took some time on the phone with me. He finally made it click in my head exactly what was going on, and what to do, what to look for, how to adjust accordingly, ect. Have I improved? Most definitely. Am I an expert? Not even close.
If you get stuck, give Tuf a shout. He gets a bad rap for being brutally honest, but the man knows his stuff.:beerchug:
jellyrug
a bit.
Thx for the reply.
When I said "I have never bothered with that" I meant on my Hayabusa. I have never ridden track with the Busa and never felt the need on the street to change anything by the way the bike behaves?
170lbs weight, without clothes. :whistle:
On my 600 Gixxer, which I rode on the track, different story. The front was way too soft, I had to adjust compression right up to the limit and do some work on the rear as well.
We have a gradual speed bump in our road, my Harley the suspension bottoms out at 20 mph. I have hit it with the Hayabusa at 60-70 mph, or lower. No problem, feels like a little hill. :laugh:
Guess that is why we call a Harley a Hardly. ???
Thread starter Similar threads Forum Replies Date
WWJD stock busa track day suspension settings? General Bike Related Topics 7
P adjusting stock suspension Maintenance and Do-It-Yourself 3
Liltroy stock suspension links(dogbones) General Bike Related Topics 1
R suspension setup for stock wheelbase 1/4 Mile 6
D Stock suspension setting ???? General Bike Related Topics 10
C trade a great condition 99-07 corbin saddle for a great condition stock seat General Bike Related Topics 6
W FREE UNUSED STOCK EXHAUST - YOU PAY SHIP Parts and Modifications 0
Boosted Cycle Perf The aftermath of a 400ish HP stock engine. Turbo 8
Dopey Raising forks with stock triple tree Gen II Busa Information 21
L 3.0 second 0-60 stock Harley Videos 17
Turbo Bob WTB Gen 1 stock windshield or Aftermarket Clear Wanted 6
rubbersidedown Stock Gen II rear sets,powder coated black,sweet lookin' Parts and Modifications 0
rubbersidedown after stock gauge plates (KPH) and some Frankenstein bolts Wanted 2
captain Great day for the country and the stock market In the News 5
c10 Gen 2 stock links Wanted 9
rubbersidedown *Free* Gen II stock grab rail,maybe .....? General Bike Stuff 2
G 212hp on stock motor?? General Bike Related Topics 15
0 Fastest/quickest STOCK motor with boost? 1/4 Mile 119
WolfPack12 Gen 2 Bazzaz Map? Stock Bike w/ Brocks Alien Head exhaust Gen II Busa Information 36
C Any point adding a power commander to a bone stock bike? Gen II Busa Information 30
S Bunch of stock parts Parts and Modifications 18
B Gen 1 Stock Rear Sprocket Brand Questions Engine and Performance mods 7
Turbo Bob How Many Inches Stock Swingarm Axel to Axel Gen 1 General Bike Related Topics 3
jellyrug K9 Stock brakes Gen II Busa Information 12
F Anyone tuned for pump e85 on a stock gen 2 engine?. Gen II Busa Information 10
T What hydraulic clutch cylinder do i need for a lock up clutch on my 1300 hayabusa? (stock cylinder not strong enough.) Engine and Performance mods 3
c10 What to do with a STOCK Gen 2 Sprocket ;) General Bike Related Topics 9
c10 Stock Gent 2 Swing arm weight ????? General Bike Related Topics 12
c10 Apex 6 Wheels weight vs stock video ;) Gen II Busa Information 62
SuedePflow (2nd Gen) stock spring specs? General Bike Related Topics 8
1 2007 Hayabusa clutch pedal stock in the neutal position, unable to switch gears? possible problems and solutions? Busa problems 16
M Gen 2 busa stock gearing question Random Thoughts 24
MLTMDNS HeliBar pic vs. stock Trips and Touring 8
Narcissus Stock Rear Shock Maintainence? Maintenance and Do-It-Yourself 22
c10 Stock H2 SXE TOP SPEED General Bike Related Topics 5
T Max boost w/stock ECU? Turbo 24
Boosted Cycle Perf 400hp, 3” stretch, stock ride height and no wheelies. Turbo 45
night_ryder Replacing stock fuel pump Maintenance and Do-It-Yourself 4
swerve1 Gen1 motor stock. Add some beef! direction's? All Motor 48
TheAtomicAss Actual width of stock rear tire/wheel? (for trailer towing) Gen II Busa Information 10
M Fully stock 06 LE-time for an exhaust Engine and Performance mods 13
WuzzaCBXRider Pro Stock bike specs, fair? 1/4 Mile 4
Jake whitebird Square led relay to the stock relay board? Maintenance and Do-It-Yourself 1
Bigboy Busa2 Stock pop Turbo 25
T boost on a stock engine? 1/4 Mile 31
Tripple Threat Busa Stock shock on a 330 tire General Bike Related Topics 4
C Stock Fuel Pump Relocation? Gen 1 All Motor 3
greg3852 Stock...whats Next First Step? General Bike Related Topics 24
M Stock Pipes From 2014 Busa W/100 Miles On Them For Sale All Motor 6
craigmac Stock Tire Psi Opinions Tires 16
Similar threads
Latest Bikes
  • My first Busa - 2012
    Nice, clean and well looked after , my pride
    • Kimbo2570
    • Updated:
  • busa
    nice and clean again first ride since ecu reflash
    • bigjimbo
    • Updated:
  • A blue bike
    2017 blue & black
    • Hayabusa Wannabe
    • Updated:
  • 2011 busa
    • Hetheus
    • Updated:
  • New guy here
    • Los.great.beard
    • Updated:
Forum statistics
Threads
174,408
Members
48,405
Latest member
kmpfqprr
