Stock Fuel Pump Relocation? Gen 1
Discussion in 'All Motor' started by CWT2000, Sep 23, 2017.
  1. CWT2000
    CWT2000 Registered
    Contests won:
    16
    United States
    I have a 2000 model with the external pump.. I want to mount the stock pump somewhere else..does the pump and filter have to be in the housing it resides in now that's bolted to brackets? Or can I take the pump by itself and move elsewhere?
  2. Kiwi Rider
    Kiwi Rider Registered
    Contests won:
    61
    Darfield New Zealand
    Short answer.... either do a 'in-tank' conversion or just leave it where it is.
    Why do you want to move it anyway?
    A whole lot of work for what gain?
    I have a '99 Busa and have just serviced my fuel pump with new filter and cleaned the gunked up pump screen... what a huge difference that made!!
    No more lean surge at cruise in top gear and more power in general.
    The air to fuel ratio is now 12:1 to 14:1 on average, from 16-20:1 as it was before the service.
    The spark plug color is now amber on the porcelain insulator instead of white, with sooty deposits on the rim.
  3. CWT2000
    CWT2000 Registered
    Contests won:
    16
    United States
    To get it away from heat..I'm not going to go with tank swap
  4. michael parris heuberger
    michael parris heuberger Registered
    Contests won:
    120
    new bedford ma
    Hi. you could up grade pump, filter & regulator. Call Frank at Powerhouse 631-491-6767. He can set you up.
Loading...
Share This Page
