Who makes the ball mount in this picture:
My understanding is the damper prevents, "tankslapping" if we change the viscosity because it "feels" better, do we affect the performance of this "sometimes" critical component? Possibly opening the door for tankslapper?
It would be interesting to see who gets tank slappers, and what modifications preceded them.
Great question!
The key word in your statement is "Prevents"!
Tank slappers on modern bikes are extremely rare. You have to do something really harsh to get your bike to enter a tank slapper (Not to be confused with head shake). Everyone gets a little wriggle or shake on odd occasions when the front tire leaves the pavement or most common when one has been playing with the suspensions ride height and ends up with to little trail. Or maybe the most common cause is use of the rear brake at the wrong time?
If you have ever experienced a stop to stop tank slapper, you most likely got your arse high sided. A bike doesn't get a tank slapper on it's own, it takes rider input to get the bike that fookered up. However, a good well tuned damper can help to "Prevent" the tank slapper before it gets out of hand. The key is well tuned. Most riders have a presumption that the stiffer the damper the better it works. No so! A damper set to stiff is less effective and more apt to compound the problem than a damper set to light. I find most riders and many racers have their aftermarket dampers set too stiff. There is a reason your stock damper has light weight oil. Any stock damper with 80/90 wt oil is much less effective than OEM oil.
There are exceptions. If you are doing rolling stoppies for instance, you need a very stiff damper. When I'm out practicing stoppies, I crank my ohlins damper up almost to it's limits on the stiff side. When you are balanced on the front tire, the last thing you want is the front tire to become the least bit unstable or you can quickly get pitched on your noggin!
My point is, if you are going to modify your stablizer, be sure you are making an improvement. Chances are you'll never need that damper unless you stunt or race, but if by chance you do, the difference in a damper that works or just feels good can mean the difference in going home to wash your skivies or getting a very expensive helicopter ride!
I used 80W90.
It works perfect. !
The reason it's perfect is because you've never needed it!
However, before you can say it works perfect, you must give it a test!
If you truely believe you have the answer, pick the front tire up and carry it up to about 80 knots and set it down crossed up. If you survive unscathed, I'll be most happy to acknowledge you have a better mouse trap!
Oh, be sure to have a friend video tape the test ride just in case you are wrong.
I was told you went suppose to use dual weight oil like 80w90..
When I said it worked perfect I meant it steers perfectly.
IMO
No Problem, I assumed you meant it functioned perfect.
Here is how your OEM damper works. It has a small orfice in which the oil passes through as you turn your steering. The oil is light and passes through very easily under normal steering.
If you get your bike into a tank slapper or even a head shake, the faster your bars go back and forth the faster the oil is forced through the orfice. The faster the oil is forced through this tiny little orfice the more resistance is created, thus damping the shake. Everything works exactly the way it was designed.
Now you take that light 10w oil out and replace it with 90w and you put the bike into a tank slapper. I need not remind you that a genuine tank slapper is extremely violent. I can vouch for that from personal experience. As the speed of the bars increases the heavy oil can no longer be force through the small orfice and the steering totally locks up. GAME OVER! Has the same effect if you have an aftermarket damper set to stiff.
As I said earlier, there is a reason those little guys in Japan designed your stock damper with light weight oil. It's not just to make your bike steer easily at slow speeds, it's designed to best manage the bike when it's most needed. Are there better dampers? Certainly.
If you are happy with your 90w damper, great! You'll most likely never need it anyway. I'm simply sharing my views (Food for thought) with those who are considering a damper modification.
