Hi folks
Need help
Having problems starting my busa
With a fully charged battery, The busa starts immediately.
After taking it out for a spin,When I try to start it, It won't turn over,It sounds like a flat battery but it's not.
When I put a multimeter on it it's showing 12.60 volts.
If I leave it for a while, The busa starts straight away or if I put jump leads on it it starts straight away.
The battery is almost new
Someone has said it might be the starter clutch
The busa is on a 2010 plate with only 7500 miles recorded so I think I can rule that out, Also, If it was the starter clutch,Getting a jump start surely wouldn't make any difference as my battery is showing 12.60 volts
Any ideas please?
Thanks folks.
Need help
Any ideas please?
Thanks folks.
