doug24nellie
04 Busa has new stator, new fuel pump, new injectors, new battery, new regulator...turns over, sounds like it wants to start but wont...sprayed some starter fluid in it and it runs until fluid is used up... took the tank off, the lines are full of fuel but dry in injector ports and throttle holes... check for clogged fuel lines and injector ports...all clear! Any ideas?
