Start button does nothing fuel pump not priming
Joshmc628
05 busa with 99 engine. Had issues with bogging out at low rpm so I changed spark plugs and took off fuel pump to clean it out. Put everything back together and the bike sounded amazing for a few seconds then cut off. Now the start button does nothing at all not even a clicking sound. Fuel pump also not priming.
I’ve tried: New battery, Bypass kickstand switch, bypass clutch switch, new fuse in every single slot, reseating relays, reseated connections on ecu, tried an entirely different killswitch.
With multimeter I’m getting no voltage at the fuel pump and no voltage at the starter. There is volts making it to fuse box. I can get the starter to spin by bridging the starter relay. It still doesn’t start because nothing is happening at the fuel pump (no volts there). Where do I go from here? I feel like I’ve exhausted all my knowledge so any help is appreciated
Joshmc628
Is tip over switch disconnects or in wrong place
Going to examine that next.
Do a search for ECU swaps and compatibility maybe .
ecu should work as I’ve taken my 05 flywheel and tps sensor and put on the 99 engine
When you turn the key on do you get voltage to ECU large connector pin #17?
Nothing there, even took the pin out and tested it to ensure good connnection to multimeter.
202mphbusa
Going to examine
had to put in my 05 flywheel and tps sensor for it to work with this ecu. I’m hoping it’s not burnt out or something, gonna take a few we
If you are sure there is no voltage there, (some multi meter tips are too big) Probably not your ECU that wire needs to be 12v for the ECU to turn on
Start back chasing that wire till you find 12v
Joshmc628
Will do, thanks for putting me in the right direction
Joshmc628
I would throw a test light between ground and that pin. then by just switching the key on you will see if it lights
Probably easier then voltmeter
No luck with a test light. Light turns on direct to battery but connecting it to pin 17 with ignition on does nothing. Looks like I may have to cut open this harness and trace this wire back?
202mphbusa
I can look at a old beat harness I have to chase it But I am heading out for a couple hours
I was saying I would leave the test light between pin 17 and ground then you can just toggle the key and see, instead of having to fumble with a voltmeter
Unplug and re-plug all the connectors up under the headlight assembly
also wiggle all the wires to the RH control assembly
Berlin Germany
if not done yet, change the ´99 flywheel (generator´s rotor) to the ´05 and everything should work fine
the ´99 has only 8 outside "bumps" - the ´05 has 23 bumps
that´s the little fault in your system.
with the old ´99 rotor your ´05 system get not enough impulses - 23 it needs but it only get 8
you have to change the rotor but no other changing of cables or so is necesary.
i wonder a bit that the engine did start.
so control all fuses first - i have no clue but perhaps one of them melted
Joshmc628
Thanks but the flywheel has already been swapped as well as the camshaft sensor from the 05
Joshmc628
If it ran, your swap was good. As pie-guy @SSGT_B said, check your tip over switch.
Alright tip over switch was still mounted nice and snug. Took it down and opened it up. Everything inside moving freely. Hooked it back up and now I can get starter to turn with the starter button(weird). Still no power to fuel pump and still no volts on pin 17 at ecu. Also getting flashing f1 light now and when I pulled the code it says c41.
Thread starter Similar threads Forum Replies Date
E 2006 Busa won't start after starter button repair Busa problems 11
S 04 Busa won't start, nothing with starter button depressed, ideas? Busa problems 10
redkat05 Anyone ever install an aftermarket push button start in a car/truck? Random Thoughts 12
K Did oil change now it wont start...smh!! Busa problems 89
T Gen 1 CHEC light no fuel prime or start - Fix Busa problems 0
N Fan. When do they start working? Gen II Busa Information 1
V 01 Busa Won't Start Busa problems 28
K Bike moves when i start it, it seem like i am not holding the clutch Busa problems 22
D Ist gen no start Busa problems 5
T 200 busa won't start wont turn over Busa problems 21
C 2006 LE NO START Busa problems 25
rubbersidedown Wanted to start a thread in "Geographic Riding Locations" but got this... Random Thoughts 1
rubbersidedown Hard to start.... Turbo 10
pashnit Ready for the ride season to start General Bike Related Topics 13
L gen 2 no start Busa problems 1
E My bike wont start up Busa problems 12
SmokeKingOfCali99Hayabusa 2008 Gsxr 1000 Wont Start. Need Help !! General Bike Related Topics 17
B Gen 1 hayabusa hot start issues General Bike Related Topics 17
B Gen 1 hayabusa hot start problems General Bike Related Topics 1
Blacksmith No start after dead battery... Gen II Busa Information 26
W Ticking after start up Busa problems 12
J Anyone Know What This Make this Jump Start Setup is? Gen II Busa Information 6
6 Gen 2: Ran fine, now cranks but won't start Busa problems 40
Tetsuo1000 Frosty start Trips and Touring 17
Kc0827 No start Busa problems 5
S No Start, No Dash Info - Bad ECU? Busa problems 10
SmokeKingOfCali99Hayabusa My 1999 hayabusa won’t start. Replaced the clutch switch. Still was doing the same thing. It’ll crank up then I’ll turn it off. Then try to crank it a General Bike Related Topics 35
G no start-- fuel injectors? Busa problems 6
Huntercs10 My 08 busa won’t start Busa problems 8
Tim R 2017 hard to start after being serviced Busa problems 9
S 2007 Busa crank, no start Busa problems 4
L Hayabusa has gas and spark but wont start. Busa problems 6
B What’s the safest rpm to start spraying? Nitrous 18
H Crank no start help Busa problems 22
F Blows main fuse when I start it Gen II Busa Information 2
T I have spark and fuel but engine wont start. Busa problems 16
Swiftfalcon Busa Dont start after a start stop trip General Bike Related Topics 5
Tetsuo1000 Start of a good summer General Bike Related Topics 8
B Getting harder to start hot General Bike Related Topics 25
Leut_Dan 1999 Hayabusa dying at operating temp, then won't start until cooled. Busa problems 29
Tetsuo1000 2010 no start Busa problems 11
J Please HELP bike won’t start New Owners Forum 26
B 2012 busa wont start when hot Gen II Busa Information 53
R No start Maintenance and Do-It-Yourself 14
mrbush803 2000 Hayabusa won't start Busa problems 7
K Cranks but wont start New Owners Forum 4
W NO FUEL... WON'T START Busa problems 32
Md Firdaus Bike can’t start when on side stand Busa problems 9
john blaze Make a Start Already........ General Bike Related Topics 35
megawatt Can you push start a turbo busa with a dead battery? Turbo 8
Similar threads
Latest Bikes
Forum statistics
Threads
174,634
Members
48,512
Latest member
MrBusaRed66
