Will appreciate advice from those who are in the body repair shop business, or with experience.
Have to fix a bit of track damage on a GXR600, small tank dent, some scratches on plastic.
This will be my process, help me where I may have it wrong.
1.) Tank, sand the dent and around it with 80 grit and use filler.
2.) Plastics, sand around the scratched up areas 80 grit and use filler.
3.) Sand filler down with final sand around 200 grit
4.) Scuff sand lightly rest of painted area at about 400 grit.
5.) Spray primer, two coats and sand down to 1000 wet sand.
6.) Spray final coats, black base only, how many coats will do the job? Planning two coats.
7.) Compound with three stages, rough, fine and polish, using a buffer.
