bubba_zenetti
hi all, a few questions again.
can anyone tell me what my compression ratio would be using the .080 spacer and a stock head gasket?
also, how does the stock head gasket stand up to boost levels around 1/2 bar?
is there a better head gasket and spacer combo that will give me better results for reliability and lower compression with stock slugs?
and now onto part 2 of my questions,
i am thinking of going to a set of j&e pistons with a spacer. i see a set of j&e 81mm slugs that are advertised as 9.5:1 in their catalog so i am assuming that is their turbo setup. waht sort of compression ratio am i looking at with the spacer.
i only ask this because i do not have my motor apart yet, so i have no clue what the actual deck height is and what the stock gasket thickness is so making calculations would be a bit difficult without those variables. i am hoping one of you have already done the math and could share the answer
