Small air box mod question
Busa Bill
Hello
I have a question ,when you do the small air box mod you cap the one side to the throttle body which I understand that but you trace that back to a valve which is called a Vacuum control solenoid valve which is located on the frame.
do you remove this valve ? its not being used anymore, because you have capped it off ,I like things clean looking in the engine area and instead of having loose lines caped off and laying around I would rather remove them if i could .and the valve if needed to stay for one reason or another do you cap it or leave it open .Im referenceing page 4-23 in the service manual. any help would be great.
BA BUSA
MotoGP Wannabe
The valve also connects to the ECU...if you remove it you might get a trouble code (FI light would come on)
You might try PMing Johnnycheese...he would know
Busa Bill
Got ahold of Johnnycheese and this is what he said.
chuck it and you have now an extra 12volt power source
for something(but bump the ingition fuse if you add
something big)
jay21112
(Busa Bill @ Aug. 21 2006,18:07) Got ahold of Johnnycheese and this is what he said.
something big)
I'm doing this mod now.
Any pics of what you took off and where you finally capped the line?
Latest Bikes
Forum statistics
Threads
178,444
Members
50,725
Latest member
AlmaMatter
