ALLshow.NOgo
Slight Oil problem?
My 03 had 5172 miles on it when I got it last September, has 9600 miles on it now. Since the day I got it, it seemed to 'consume' oil rather quickly than normal? There was NO visible leak, NO oil smell, No overheating, and NO smoke comming from the bike.
I would just notice that I need to put 1 or 2 quarts in it maybe in about 2 months time to fill it back up. Engine is very strong no weird noises etc. I remember a guy from H.org had the SAME **color, SAME year as my bike with the SAME problem.
Well I had my 'first' ride on Sunday. 149 is a GREAT rode for twisties. Ran the bike pretty hard, and cruised through some places for exactly 3hrs. BUT before leaving I checked the oil and it was halfway in the sight glass. Then today before I rode, it was below the 'LOW' mark?
Well I thought I would do it 'right' and put in the Valvoline 4 stroke motorcycle oil that was rated SF/SG and had high RPM protection Yada Yada. Well I just CRUISED for about 10 miles, short shifting every gear just to let the oil work its way. parked it, started it back up after 30 mins and white smoke came from the right tail pipe!!
I was like nooooooo way. It shot out and I twisted it a little bit and continued. I shut it off and the smoke still came out of the right tail pipe. well after leaving it for about 1hr I started it back up BARELY any smoke from both pipes, almost to where you could not even see it. I TRIED to empty the oil from the Hex screw but only a LITTLE oil came out so I pieced it back.
(The fairing is VERY easy to take off btw. First time I did it, and it only took 10mins including the 'look over' to see what needs to come off!)
I drove gently home and noticed no smoke, got home and twisted it, still no smoke.
Do I have to be worried??? I was thinking of getting the shop to do an oil change but not if its a waste of money though.
**Maybe this oil consumption is the reason why my color is the most aggressive/fastest of all years?
