I always hear this and wonder.
'It's been sitting so the gaskets and seals are shot. I wouldnt buy it.'
Whether it's a car or motorcycle what's the difference between a bike that's been sitting for years with oil in it and a bike that's been ridden regularly with normal oil changes? The gaskets for the sitting bike are wet and covered in oil. The gaskets for the ridden bike are wet and covered in oil. The ridden bike the oil moves around, the sitting bike doesn't. It doesnt change the soak/saturation level does it?
So how is it worse for gaskets and seals to sit in oil that's not moving compared to oil that is circulating and hot?
Or is it that gaskets/seals that would normally get wet and coated thru use do not get this from sitting and dry up or rot?
