Signal wires for TPS,GPS,SS,Tach???
turb06LE240
Wondering if anyone knows which wires are signal wires from
TPS {Throttle position}
GPS {gear position} {i believe this is Pink}
Speed sensor
And the tach signal?
Im hooking up my zeitronics and my dyno jet multi hub, so I need these wire colors, thanks in advance...
TPS - Yellow coming out of the TPS sensor. Pink with Black Tracer at the ECM
GPS Pink at the ECM
Tach Yellow w/blue tracer near the gauge cluster and the ECM
Speed sensor
Coming out of the sensor it is Black Black w/white tracer Black w/red tracer. The black turns to Pink at the first connection going to the speedometer. I don’t know what wires you connect. I hope to get my logger connected this week. The Black/White is going to ground.
Thanks a lot, I am going to guess that the black wire out of the speed sensor is the one I want
if black white goes to ground, then black red must be 5v constant and since the black turns to pink and goes to the gauges I am sure thats it..
Again Thanks for youor help, I appretiate it way much....
My datalogger should be all hooked in today and I should have my body work back monday so, she shoul be done after that...... Thanks alot....
