Some pretty knowledgeable people have asked you why you would want this. I don't want to put any words in someone else's mouth, so I'll ask too? The thought behind a progressive spring seams to be that it would provide a softer initial rate to ride more smoothly over small stuff, but still have a strong enough rate to handle big stuff. This can provide an improvement of sorts on a bike with no adjustability of compression or rebound and a stock spring that is too weak for the weight of the bike and rider (lots of cruisers and many older bikes). Current thoughts on improving bike suspension recognize that the spring basically just supports this weight, and tuning how the bike suspension responds or handles bumps and changes is done by changing the compression and rebound valving. An issue with a progressive spring is that it is practically impossible to tune C or R properly when the rate of the spring changes depending on where in the travel it is. A properly chosen linear spring rate and shock valving that is modified for a useful range of adjustment is the way to go in my opinion.
