Hell most truck drivers don't use the clutch either.
Class 8 tractors common to this country use non-syncromesh transmissions. Does your Busa?
Keith - to answer your question, I honestly don't know if there's long-term damage caused by clutchless shifting on a motorcycle. I have anecdotal evidence that there is, but in my 30+ riding years I've never been into a bike tranny - probably because I ALWAYS use the clutch to shift.
Uncle Bob stories and anecdotes aside, it's my opinion that modern motorcycles are marvels of engineering and are, generally, overbuilt. This means that Billy Squidly can buy a new bike, shift without a clutch for a couple of years, sell his bike outright or trade it for a new one and, probably in all honesty, say that he's never had a transmission problem caused by floating gears.
However, the poor unsuspecting bastard that buys Billy's bike more than likely won't be so fortunate.
I find it intuitive to use a clutch to shift a syncronized transmission because, regardless any other reasoning, I'm in the process of meshing two parts whose rotational speed is out of sync.
Also, so called 'unloading' via throttle is a misnomer, in my opinion, because it's only unloading the current gear/dog combination - it does absolutely nothing to separate, or unload, the engine and its part of the transmission from the rest of the drivetrain and its part of the transmission or to cushion the collision of the parts whose rotational speed is out of sync. There's a lot of rotational mass there, and only a few small parts to withstand the shock load. Using a clutch greatly lessens the shock load.
Race teams get away with clutchless shifting because the bikes are specifically modified to withstand it, and they're torn down constantly. You people who shift without a clutch - have you modified your bikes to withstand clutchless shifting? Do you tear your bike down constantly to make sure it's in top shape? In fact, when was the last time you split your cases to
verify that there's no damage caused by shifting without a clutch??
Yet it's amazing how often the subject of metal in the oil comes up...
Lastly, I often hear about undercutting in connection with this topic. The information I've read suggests that undercutting doesn't enable transmissions to withstand clutchless shifting, but rather, undercutting enables the dogs and selected gears to remain locked together under power.
At least this is all to the best of my understanding.
I guess I'd ask you a question Keith: How long do you plan on keeping your bike?
Steve
