I have put 8-9000 miles on mine since changing from the "clutch every shift" mode. Tranny is great, smooth shifting and no issues.
Now I clutch for 1-2, then the rest of the upshifts I pre-load the shifter with the same force I would use to shift it, then roll the throttle 1/8-1/4" forward and back and it just snicks into gear! It is SO easy and smooth, when putting around town it feels like an automatic transmission.
Think of this:
We all take it for granted after doing it for so long, but think of all the muscle memory involved in shifting: left hand pulls the clutch 1-2 inches in, then lets it out to the bite point and on to full engagement-right hand rolls throttle to full off, then back to an estimated point to match RPMs-left foot coordinates moving lever in time to this left/right hand dance.
Now try this instead-left foot applies pressure at a non-critical time before shifting, then you simply roll the throttle forward slightly and then back.
Think with practice how much easier and precise this small movement becomes to get into the next gear, and at the desired RPM setting. You can roll onto the throttle so gently you feel NO jerk, then ease it on a fractional second later to continue accelerating, or just slam it back to accelerate hard if you are so inclined. Think also how much faster this is with practice, it's almost instantaneous!
That being said, I will continue to clutch for the 1-2 shift because Suzuki was cheap and stupid with their flagship bike and didn't undercut second gear and it sucks. I can't afford a new transmission. I will ALWAYS clutch for all downshifts, even though I match RPM when shifting rather than blipping the throttle.
I know, I know, it SOUNDS cool to blip the throttle when downshifting but I have found it easier to move the throttle to the RPM I will be in when I downshift and hold it there while I shift. Very smooth gearchanges, no jerk and minimal wear to the clutch when I let it out. Again, It's MUCH easier to move the throttle a small amount accurately than to try to match a rev point by ear, I believe most people blipping throttle do not have a smooth downshift and it's more a matter of habit and the clutch makes up for the inaccuracy. JMHO.
So, do NOT be afraid to try this, most of you will be amazed how easy it is and how much smoother it is with practice. I promise you a grin the first time you try it!!
