G
Guest
I noticed that when I do a "normal" (low speed) shift from 1st to 2nd, the shifting is smooth with almost no backlash. However when you have a mighty launch on 1st gear then shift to 2nd, the bike's speed diminishes abruptly, unless you whack open the throttle as soon as you release the clutch in 2nd gear, or if I shift from 1st to 3rd, skipping the 2nd gear. has anyone noticed this? Is it the Fuel Injection system? Also riding at very high speeds and closing the throttle to slow down, prior to shifting down, you can feel the power being cut off quite rapidly. Any comments?
