suzuki drag racer
today i installed a shift light on my busa and my bike wont start.......all the wires are hooked up right bike will turn over but wont start .....when i unhooked the wires the bike starts and runs fine theres 2 things i think it could be one is the shift minder box is bad or it could be that i'm not running the 4 into 1 tack wire with the resistor that goes from the green wire to the 4 - coil wires
what i did was take the green wire from the shift minder and splice 4 wires into it then ran it to each coil pack could this be the problem that i need the resistor in line for it to work?
? if so what size resistor would i need ........thanks for any help
