Secondary Throttle motor circuit malfunction in Gen II 2013 Busa
busaboy999
Hey Guys,
My busa had power loss after 5-6K RPM hence got it checked with the mech and the diagnostic tool showed the error P1655 which had the description "Secondary throttle motor circuit malfunction (pic attached). My Mech tried the fix by checking the STVA circuit and did not find any issue in soldering and current was passing fine in the voltmeter. Please help me guys.
busaboy999
Yeah. Even I'm inclined to replace that motor. Can you help me on identifying the correct part number from the attached pic ?
busaboy999
I can see 13th number would be the one to be replaced. But I'm doubtful whether the whole set of actuator also comes along with this!
sixpack577
Top Gun
It is number 13.
Just an electric motor basically.
It rotates a shaft that the secondary throttle plates mount to, which opens and closes them as needed.
They also function better when adjusted through Ecu Editor(which is unrelated to your issue).
It is also simple to access and replace.
Assuming that is the issue, which it seems to be, you should not need any other parts to go with it, as the rest of that system is mechanical. And, there would be a seperate code for the throttle position sensor.
GIXERHP
To be honest here, put the bike in dealer mode and see what shows for a code first!
The Suzuki manual will then tell you how to diagnose it
What your mentioning i would have to say and i have seen a the Ics solenoid gone bad.
What is done to the bike overall?
busaboy999
Mech has checked all plugs, cleaned throttle body, and lines. No issues.
I guess the code is p1655 as per diagnostic tool as I have posted in the first pic.
sixpack577
Top Gun
Problem is still there. FI light came for the first time. now one more error code p0110h is shown
Have you checked for codes yourself?
As in a jumper wire in the white diagnostic plug under the driver's seat, red/white to black/white wires(dealer mode, what Gixerhp was talking about).
That will display the letter C on the dash, and a 2 digit number. C00 means no codes present, any other number references a specific fault(search the list here). Leave the jumper in while you ride too, that way if the fault comes and goes, or there is more than one, you'll see it, as the ecu does not store codes.
See if the code is referencing the same problem as the Suzuki software.
RedBull
#AirTemperatureSensor ~ #ThrottleCircuitMalfunction ~ #THEoRg *
GIXERHP
Put it dealer mode and see what Suzuki code it come up with, Ill bet its C41 ICS
Thread starter Similar threads Forum Replies Date
I Brocks secondary throttle plate removal Engine and Performance mods 23
D Secondary Throttle Valve Actuator Specs (STVA) Gen II Busa Information 0
1 secondary throttle blade removel Turbo 8
F What triggers secondary injectors on 2008 (Gen 2)? Electrical Mods 21
Ogbigboybusa Secondary Fan Help Busa Mods 2
X Hard Fuel Rev/cut And Secondary Injectors Controller On Boosted Application Turbo 11
R Secondary Injectors Turbo 7
Busashot Mc Express Turbo Secondary Controller Turbo 5
J Secondary Spal Fan - Ultra Kit Turbo 1
LeDauz micro tech for secondary injectors Turbo 5
Corso1 Flies out??? Secondary Butterflies on a Gen2? Engine and Performance mods 4
F Gen2 secondary flies Gen II Busa Information 3
T Tuner Poll! - Bigger injectors or secondary fuel rail? Turbo 5
jesusfreak2111 secondary fuse Maintenance and Do-It-Yourself 4
N Please help me on the SFM ( Secondary Fuel Module ) Gen II Busa Information 4
Dozerdriver Secondary Butterflies removal review Gen II Busa Information 212
sixpack577 Removed Secondary Butteryflys General Bike Related Topics 57
W Secondary injectors Gen II Busa Information 3
T Alternative Secondary Controller Option @1/2 the Price Turbo 3
Dozerdriver Secondary Flies..? Gen II Busa Information 10
jch364 secondary fan system Engine and Performance mods 9
P removing secondary butterflies Gen II Busa Information 16
Evil_keeps_me_young secondary butterflies? Gen II Busa Information 21
TA_GunSurgeon Secondary Butterflies Gen II Busa Information 7
E Secondary Injector Controllers Turbo 21
The Big Red One Will the 08 busa have secondary flies like the 14? General Bike Related Topics 2
delboy Secondary big time..... Random Thoughts 13
V Throttle body vacuum lines Turbo 4
N 2006 missing/surging at low throttle Busa problems 3
C 2004 throttle body problem/erratic idle Busa problems 3
J How to fix jerky low end throttle Gen II Busa Information 10
T Busa jerky throttle Busa problems 4
S 99-07 throttle bodies with injectors Parts and Modifications 1
T Throttle bodies gen 1 Wanted 3
SeaMonkey 1999 throttle body Parts and Modifications 4
Cncbusa Single throttle body Turbo 13
N Low rpm Jumpy jerky touchy throttle Busa problems 14
M Engine cutting out when throttle cracked Busa problems 19
Bumblebee Throttle Body Cleaner Gen II Busa Information 8
J F1 light and throttle hesitation after new exhaust install General Bike Related Topics 19
Tetsuo1000 Atlas throttle lock Busa Mods 4
wigpuller I have to replace my lower throttle position sensor Busa Mods 2
J Balancing throttle bodies. General Bike Related Topics 3
J Throttle problem Engine and Performance mods 1
D Lot of smoke under heavy throttle? Turbo 10
E Zurcher Throttle Response Question Busa problems 5
Z-MAN74 Gen1 throttle body sync General Bike Related Topics 5
Jugghed Full Throttle Boost Drop Turbo 4
bussassin417 Quarter Turn (quick turn) Throttle's General Bike Related Topics 25
S Looking for a Throttle Position Sensor – gen 1 General Bike Related Topics 5
Similar threads
Latest Bikes
  • Bam Bam
    My Last Little Girl
    • rlmoorex
    • Updated:
  • My first Busa - 2012
    Nice, clean and well looked after , my pride
    • Kimbo2570
    • Updated:
  • busa
    nice and clean again first ride since ecu reflash
    • bigjimbo
    • Updated:
  • A blue bike
    2017 blue & black
    • Hayabusa Wannabe
    • Updated:
  • 2011 busa
    • Hetheus
    • Updated:
Forum statistics
Threads
174,469
Members
48,442
Latest member
sman708
